m1009 front axle ?
PAm1009
hatboro,PA
just got a 1009 not too long ago amd was wondering what kind of front diff the m1009s came with. i know the 1008s are dana 60 didnt know if that applied to the 1009 too.
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
Both are GM Corp common in that config and same as civ K5 Blazer Front is Open Diff rear ia Pos track.
it was equip with 3/4 ton springs.
91W350
57
Salina, Kansas
Can we just pull the carrier out of a rear differential and put it in the front to get true four wheel drive? If your rear axle does not act like it is pulling with both tires, sometimes a quick tap of the brakes under load will kick the locker into driving both rear tires. They are not nearly as good about locking up as the Detroits are. Glen
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
GM Corporate 10-bolt (8.5-in. 1.28 Axle Dia. 30 Spline
The front and Rear will inner change with each other.
91W350
57
Salina, Kansas
Thanks, I know where there are three M1009s with no front axles headed for the crusher, the rear axles are still there. Maybe I can talk him out of some parts. Very tough guy to buy from though. Glen
crasheej
Hermitage,MO
Don't you just l--e those guys . I got it and I'm not going to help even if i could. But maybe i might but I'm going to restore it one of these days. Then you hear that it all went to the scraper.
91W350
57
Salina, Kansas
All that stuff is gone, the doors are gone, tailgates are gone, engines are gone, transmissions are gone. There is a shattered transfer case. Rifle racks are gone, some have wheels, but they have been sitting on the ground. The fuel filters and bases have been removed, the beds are full of scrap metal. They are crusher fodder, but the rear axles are still there. At least they were. Glen
MuleMac01
Military vehicle collector
883
135
Las Vegas Nevada
omg i wish i had the money i could use a rear axle i think mine is bent but i don't know. never had a axle like this befor it looks funney it might not .
harbordr
PM sent, If you deal with this guy, I want in.
NICK_M1009
Brown City, Mi. (The Thumb)
If you take the carrier out of the back and put it in the front you will have to re-set your ring, pinion. No big deal just time consuming. I thought about true 4wheel for my blaze-o and my idea was to put a spool in the front. Lock one hub for 3wheel drive, and when needed lock the other hub in the mud and what-not for both front tires to turn. I havent done it but only lacking 90 dollars for the part...
