Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Maybe 5 on each side, and 5-6 across the back of the cab roof? You should be able to count the number of holes in the top or the bedsides to tell for sure.
The 2 rear bolts on the corners are 3/8" coming up from the bottom flange and the rest of the bolts as mentioned are all 5/16" of 2 different lengths. The cab to roof has self aligning tapered bolts because all the caged nuts are floating in the cage for ease of alignment. You do not need to use tapered body bolts but it helps. Getting the nuts in alignment with 1 tapered bolt and following up with the proper length 5/16" bolt is as easy as that. Being that you are in Palmyra I am 10 miles from you. Just food for thought. Take Care and Good Luck.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
