Hi guys.
The solution was to turn on the hi-beams to test to see if they would work, they did,
then when I switched it back to low beams, they worked.
It seems like the turn signal/hi-beam lo-beam/dimmer switch in the column, got stuck between low and hi-beam,
so when I flipped between lo and high about 2-3 times actually, the switch got righted, and now the lo and hi beams work fine now.
It feels like that switch is worn out a bit, so I will buy a new one, and replace it as soon as possible.
Good night.
