RickTheEngineer
- 5
- 16
- Mount Laurel NJ
Hello everyone, hope all is well. Got a question regarding the stock TH400 oil cooler lines on my M1009. I am getting down to where my transmission is leaking (losing 500ml per 3-4 weeks). I think that my oil cooler lines are suspect. The reason why I say this is because I am seeing some wetness near the driver side wheel well on the frame as well as wetness on the hose where the steel fitting is on the rubber hose in that area. (This line leads into the radiator, so I'd imagine this is the oil cooler line?) I found some part numbers (NAPA)... BK 8232229 (upper) BK 8232235 (lower). Here is what I don't get though, these lines aren't the kind that go all the way to the radiator are they? Or are there more lines that I need to buy to do a complete repair? Most of the trans oil that is leaking can be found on the passenger side frame kind of close to the starter. Any thoughts? Or part numbers? I apologize for my lack of knowledge on the topic. (The year is 1985 by the way!)
