chief1983
- 1
- 16
- Saint Charles, MO
My M1009 hasn't been running quite right lately, so I've been digging in and checking all the things I've found mentioned in the TM and online. Too hard to start when cold, ticking sound near oilpan that's grown very pronounced lately, engine sounds much louder than normal most of the time but that sound does occasionally cut out.
Flex plate and torque converter all look good, no loose bolts/cracks. Power steering mounts are fine. Haven't cracked open the valve cover yet, that's on my todo list. Did find a missing nut on the starter bracket, came in just now to check the TM for what should go on (locknut, washer, etc, proper torque, although I don't think I can get a torque wrench in there) and thought I'd make an update so anyone might have other things for me to check, if none of the things I'm doing clear up everything. Still plan to check fuel pump pressure to see if that's related to my cold start woes, lift pump could be shot.
One of my glow plugs was unhooked when I got the truck, with the resistor setup would 7/8 of the glow plugs on lead to enough overvoltage to ruin them? Everything else about the GP system _seems_ to be working correctly, but I got a new set of Wellman 070s only to find no one here seems to recommend those due to swelling. Haven't taken out the old ones yet. Proper way to check voltage to glow plugs without disconnecting them and overvolting the rest is...? It's quite sad, I really should be more competent with a multimeter.
I attached a pic that shows the locknut and washer that were missing, going to go install a new one and see if that helps the noise. Also installing an oil pressure gauge to make sure my oil pump is at least still working enough to pump oil through the engine. Pics of that install will be in my thread about the Equus pressure gauge.
http://www.steelsoldiers.com/cucv/65406-want-install-equus-6244-oil-pressure-gauge.html
