M1009 opinions before IP change
ms1223
Illinois
My 84 M1009 will start run for a couple of miles loose power and stall. I checked the fuel for water, new fuel filter, checked for air leakage and cleaned the return line check valve a couple of times. Fuel pump pressure is good.
Any suggestions before I go after the IP? It seems to run good after it stalls only for a few minutes. Does the return line check valve go bad?
Any suggestions welcomed.
Thanks, Mike
Ken_86gt
Williamsburg VA
Was the check ball dirty enough to require cleaning? If so, you either repair the fuel pump or remove the check ball....For long term reliability I would look into the fuel pump.
tequilaiam
Brazil, IN
How do you know if there is air leakage?
My experience: possible that air gets in but fuel doesn't drip out, making it impossible to source a leak. I bought clear fuel line and quickly IDed where the leak was comming from.
Check your water in fuel sensor in your fuel filter assembly. I found mine had a tiny pinhole leak that sealed up when pressurized by the pump but let in a little bit of air to allow the filter housing to drain back to the tank. therefore, I could start it up then after a little while that air bubble got sucked into the IP and stalled it.
ms1223
Illinois
Thanks for the info. When I cleaned the ball check it had a small amount of small hard particles. I put a clear hose on the retun line and saw no air bubbles. Fuel is good pressure. The truck will run good for ten minutes after sitting for a few hours. It then stalls, has no power, it will restart immediately. It will stall when slowing down, it's a real treat when you restart with you your foot on the brake trying to slow the truck
Barrman
1,712
Giddings, Texas
If you had particles in the check valve, your IP is coming apart. Start planning for a replacement or rebuild. The stalling while coasting is another sign of it dying.
