top_prop
- 8
- 18
- Suffolk, VA
Like I posted above, I put one of these Vista Pro's in my CUCV and another in my 87 R20 Suburban... one of them developed a leak at the solder joint (about a year after installed) near the upper radiator hose. Got a replacement (I purchased mine from Advanced with a lifetime warranty). When I pulled the covers off the oil cooler lines on the new one the female threads were completely corroded... had to go back and get a replacement for the replacement... second replacement was ok, but had a little corrosion there too (like the original poster's pics). Also had large chunks of solder floating around it it. Had to shake them out.
Seems like the manufacturer has quality control issues.
