rnd-motorsports
- 3
- 0
- Evart,Michigan
You want the temp gauge in the front driver side you can remove the sender if you like that sending unit is for the temp light only the pass rear unit is the glow plug temp sender. the thermostat sensor side should point into the crossover pipe the stock on is 195 even then just put a new on and only get 180 steady with a auto meter gauge installed and that drops about 5/10 deg. if I have heat on high the 6.2 with the larger rad. really run cool to start with
