91W350
- 59
- 48
- Salina, Kansas
Timing Chain is where I was headed when I asked about the sound of it cranking. You should have been banging at least on starting fluid. I never use the stuff on any modern diesel, and especially not on glow plugs or plenum heaters. When the timing chain breaks, frequently it will sound like it has compression on on cylinder. It also stops the IP from pumping or distributing fuel. It could be the drive for the IP or more serious damage, like a broken crankshaft. The guys are giving you good advice on watching to see if that timing gear is turning.
