- 8,302
- 724
- 113
- College Station, TX
I've had ongoing issues with my speedometer that originally was OK but then after a lub job while on the road it started going goofy and now outright doesn't work other than the occasioal bounce and on rare occasions reading the wrong speed (like 15 mph while actually driving around 50).
I took apart the sensor and cable and speedometer and lubed everything. No go. Then replaced the cable. No go. Swapped out the speed sensor for another used one that was working. Nothing. So I attached a drill to the speed sensor while it was attached to the cable and speedometer----it turned at the anticipated 35 mph (or about that since soldier B was a 9 year old girl that hasn't done anything like this before).
So there's a piece in the bell housingthat would be the next issue--correct??????
Want to confirm that the part in the bell housing is the same in all the other CUCV series as the M1009? If anyone has one that is functional, let me know.
