M1009 Stalling while driving
Pballer71
Michigan
Yesterday i was driving my M1009 it was running great no problems what so ever then all of a sudden the truck just shut off. So i costed to the side of the road. I tried to start it for a few minutes and it wouldn't start. So after sitting there scratching my head for a few minutes and looking up online what might have happened i read somewhere to dump cold water on the IP. So i dumped a little water on it and tried to start it again. The truck started right up like normal. Then after a few miles on the way home it died again. Tried starting it again and no luck so i dumped more water on the IP and it fired right up and i was able to make it home. So my question is does this mean its time for a new IP or what else could be causing the truck to shut off like it is?
KansasBobcat
9
San Antonio, TX
AM General factory trouble line told me to put wet cloth on IP when I had hot start problem. It did work but have later read several places that is not a good idea and can cause damage to IP.
edpdx
80
Oregon
PBALLER71, Also check all fuel lines for cracks. Probably should look around the filter for any signs of leaking fuel. I've had issues like this where the crack stays closed when cold, but as the rubber heats up and it is more pliable, it starts bouncing around and sucks air into the line as it lets fuel drip out. The ngine becomes fuel starved and dies. The cracks can be hard to spot if you don't bend every inch looking for them.
Good luck.
