M1009 Starter/Switch help.. need some pointers.
royalflush55
552
Reydon, OK
Cucvrus.. I am breaking out the test light and following the fuseable links down.. how many are in line with the starter?
and could it be ignition switch?
Or anything else you can think of.
Really appreciate your guys help. Thanks for your time and knowledge.
There are two fusible links connected to the 12 volt diamond in the center of the firewall. One of these goes to the ignition switch. Pull on both of these fusible links pretty good. The fusible link can look ok but will stretch or pull apart if burnt. If one pulls into replace with proper size and it should start.
