M1009 Tailgate Window Question
zyrtecx
Western NC
What Components inside the tailgate that controls the windows cranking up and down usually breaks or go bad, that would cause the tailgate glass not to go up or down? The crank just turns and nothing happens... The regulators in the door had been working ok!
Is the Cam broken?
Tnrobocop
Mobile, Alabama
Sounds like you need a new window crank. It has tabs that engages the bowtie looking piece on the regulator.
Best thing to do is take the access panel off the tailgate and then try to operate the window.
I had to replace the crank and the regulator on mine. The crank was missing and the regulators gear were shot.
ida34
30
Dexter, MI
I hate to get real simple on this but is the crank unlocked? If it is locked then it will spin free. The lock allows it to engage with the mechanism to raise or lower.
HardCorps79
Kansas City, MO
I wasn't gonna say anything... :roll:
(Kind of like the "I don't have lights...Oh, my toggle switch is off" issue).
Pawnshop
20
Austin/Cedar Park Texas
I bet it's the potmetal "link" betwixt the crank and the mechanism inside that is designed to explode if the window binds (preventing greater damage), LMC sells them.
pbrstreetgang
Kentucky
Tailgate Window Jamming
I am having a similar problem with my glass. I just installed a replacement window last night and everything works fine, but 1 / 3 times rolling the window up, the window frame along the bottom, catches on a piece in the middle of the tailgate near the crank. I kept my access panel off to watch this happen and it is easily corrected if i reach in and pull it out a little, but then it happens again.
Any thoughts?
CUCV85
central/ny
I had to replace the crank regulator, then I put a new lock cylinder in there, the pieces I got from a chevy dealer: spring, cam actuator - small foot looking thing. :idea:Remember if you have valuables in there get a lock in that crank and use it. My cousins tailgate was catching on the way down, the tailgate was sagged in the middle so we took off the inside plate and carefully bent it up about an inch - oiled all the gears and wala.
3dubs
Houston, TX
Mine did the same thing. The handle part broke inside. Buy the complete handle. There is a small sping that pushes a small metal piece that engages when unlocked. With shipping it is easier to buy the whole thing and swap the lock cylinder so you only need one key. LMC carries it.
jsuandrew
Guntersville, Al
My back glass window crank on my M1009 doesn't have a lock. Does anyone know where I can get a window crank that locks? And possibly a set of door locks to match?
