M1009 Tires and Lift
AJMBLAZER
Paducah, KY
The 2", 4", etc refers to lift heights.
The 52" and 56" refers to the lengths of the rear springs. 52" goes under half tons and light duty 3/4 tons and 56" go under heavy 3/4 tons and 1 tons.
You'd want a lift spring set or replacement spring set meant for a half ton truck or K5 Blazer.
Personally I'd go with a 2" lift spring setup. Better ride but low enough to not really affect anything else.
CR99
I thought the m1009 was a 3/4 ton technically, so would that imply a 56" length? Also, would you recommend the EZ ride or the Heavy Duty (HD) model springs? This is a daily driver with offroad use about 25% of the time bc of the roads here...thanks for the help!
AJMBLAZER
Paducah, KY
What they said.
Definitely go with the EZ ride on the Blazer and yours has 52" rear springs.
A 2008 half ton can tow and haul what a 1968 one ton could tow and haul. However it's still called a half ton. The military just rated them by what they were capable of hauling so a "half ton" K5 Blazer is a 5/8 ton CUCV to the military. Likewise with the pickups - 1 ton K30 = 1.25 ton M1008.
