kapnklug
- 2
- 18
- spencer,ny
Been driving my 85 M1009 ("The General") for three years, and now its time for General V2.0! It's getting a set of 3/4ton axles, 2" add-a-leafs and Zero-rate blocks, 35X15 Swamper TSL-SX tires, and the turbo setup from a '93 K3500 6.5TD.
Heres some pix from the first stage, swapping in the GM 14-bolt rear axle. This went pretty smoothly, but required a conversion U-joint at the rear pumpkin, and some modification to the parking brake cables. I'm currently driving it like this (2WD only!). The 4.10 gears with 35" tires give it much better throttle response without winding out all crazy like an M1008.
Next step will be more complicated, since I plan on removing the front clip to replace the front axle, rebuild the heads (right bank is smoking blue) and install the turbo. Pictures will be posted as work progresses.
Heard different opinions on using the (.010") thicker head gaskets when installing a turbo -- anyone want to chime in on this issue?
