M1009 Turns over wont start/ Not getting fuel out of thumb nut at fuel filter..
OGMurph
Los Angeles, CA
Hey Guys,
If you have read this far thanks for reading and any input you may have. I have diagnosed my truck for the last 5 years and with the help of the manuals and this site.. so far ive tackled most things.
Yesterday i went to start my daily driver the M1009 and it would not turnover. It cranked and cranked but it didnt turnover. I have the Doghead starter relay mod in my truck sense i purchased it. The previous owner had done it himself.
I had one of my glow plug wires melt and cause a overvoltage/burn out of my glow plugs 2 years ago. I rewired the system and swapped the connectors to the 60g Glow plug. So i suspected the glow plug system first but i was unable to get it firing after installing new plugs. So i went on to change the fuel filter just to see if i could improve the fuel flow. When i went to prime the filter and i could not get any fuel to flow out of the filter housing thru the thumb nut on top.
What do i test next? Fuel sending pump in the tank? This is beyond my depth of knowledge.
Miah
29
Kansas City-ish, MO
since you know you don't have fuel @ the filter trace the fuel lines back from there. Look for cracking or wet spots that could indicate leak or air getting into the system. Stock it doesn't have a pump in the tank, the mechanical fuel pump is on the front passenger side of the engine. Do you know if the pump & rubber lines have been replaced at any point & how recent?
OGMurph
Los Angeles, CA
The pump itself is pretty wet. I had a lot of the cracked hoses replaced when i got the truck 5 years ago. I've got a small drip from the oil pan so everything is a little dirty/wet.. but the pump is seeming real wet.
I have a spare fuel pump in my truck just have never done the work before. I guess ill have to read the manual to see if i can do it infront of my aparment. Dont have a garage anymore :/
cucvrus
9,630
Jonestown Pennsylvania
Easy. Remove the right side (passengers) Gen 2. alternator and bracket and you can do 90% of it from the top side. Remove everything including the push rod cover. Clean the area really well and the gasket surface. Make sure you have the correct fuel pump. Post a picture of the lever and we can go from there. It is a project that takes less than an hour but 4 hours may be needed for a beginner. I am here to help. More later.
