m1009 u-joints
maritimer
Yarmouth, NS
ok so i am ready to put the new trans up and relized i need u-joints on both ends of the rear driveshaft.
now the las ttime i went to napa, they gave me to of the same joint, and for some reason the transmission side fit no problem, but the pinion or axle end, was a differnt odd ball joint, the driveshaft side was one size of cap/ear, while the axle side was a smaller wiered one, and well i aint got a part number and i dotn wanna have to run into the same problem again buyin a joint i dotn need lol and then re buying another one. so has anyone got the u-joint part number for the reaxr axle-driveshaft ?
Bighorn
N/A
Spicer 5-795x
Your yoke could be worn.
I worked at driveline service San Jose for 2 years.
We saw all kind of worn out pinion yokes.
It happens. The ujoint should fit tight in the yoke even before the straps/u-bolts are tightened.
If it does not fit snug and there is any play side to side; replace the yoke.
"Inside clip"
aliases;
AKA 3R
AKA S44
Assuming you have a stock yoke on your corp 10 bolt.
Other possibilities
Variants:
3R u-joint 5-795x inside c-clip.
3R by 1330 u-joint 5-793x c-clip x outside clip
3R by 1310 u-joint Neapco3-2130 hd c-clip x outside clip 1310 style
Volvo740turbo
St.louis missouri
Spicer 5-795x
"Inside clip"
aliases;
AKA 3R
AKA S44
Other possibilities
Variants:
Are the caps equal diameter on the spicer u joint do you know? It appears the caps on the yoke should be larger than the driveshaft side
Bighorn
N/A
Yes, they are equal.
The Spicer 5-795 ujoint is a gm 3R and it fits the stock driveshaft and pinion yoke.
The only other inside clip style yokes are Dodge 7260 or 7290.
Definitely call your driveshaft man for second opinion.
