2deuce
- 188
- 63
- portland, oregon
I have this noticeable vibration that seems to be strongest while accelerating between 35 and 45. I've looked at the damper and it is rock solid true running at idle. I had a u joint wear out and replaced that and had the driveline balanced at the same time. The vibration is a engine speed resonance. It is not slow like a bad tire. Is the damper fooling me or something else? The vibration is less noticeable while coasting, but it still there but not as hard. I've watched the engine when I've given it some throttle with the brakes on and it stays put so I think the motor mounts are fine.
Thanks
Thanks
