m1009 what kind of exhaust do you run?
a68cudas
Brookfield, Ohio
What kind of exhaust system and mufflers do you guys run on your M1009s? Any better than others any to stay away from ?
11Echo
92
CT W. R.
What kind of exhaust system and mufflers do you guys run? Any better than others any to stay away from ?
If you get a CUCV and it needs an exhaust system, the best bet in your area is to go across the line to Stainless Exhaust in Fredonia, PA. There is a fellow on this site in the county north of you that sells CUCV's.
Doc Bingo
Peoria, Az.
Exhaust Replacement suggestions ...
I am looking tochange or upgrade / fix my exhaust on my M1009 ... other then going to a shop and saying that one ... can someone give some suggestions ???
Thanks...
wallew
I replaced my mufflers with a free flowing triple chamber muffler. Fairly quiet until you gain upper rpms and then you do hear the muffler a little bit more.
Does make it RUN much better. Goes well with my K&N air filter and modified air filter top.
Good air in and good air out makes her a happy camper.
67_C-30
Sweet Home Alabama!
X2 - This is a great mod on a N 6.2L.
M1008driver
Great Falls, Montana
VForce Mufflers are cheaper than Flowmaster and just as good. I had my M1008 done at a muffler shop ($647 for dual pipes and mufflers). The pipes are 2 1/2 inches. The difference in power is very noticeable on hills and the sound is powerful, not too aggressive. I will do the same some day when I get my M1009.
