Gabe92
- 7
- 3
- Atlanta, GA
My M1009 died when I put it into gear, this happens now and then when I don't let it warm up enough. When I went to start it again, I experienced a loud whining noise and nothing else. This continues to happen every time I try to start it.
I have pulled both batteries out and tested them. However they both have 12+ volts and plenty of CCA. I did notice the battery wires were hot when I went to pull them out.
The ground is good and I can't find any loose connections. I searched the form and Google, but couldn't find a similar problem. Do you guys have any suggestions? Thank you
