M1009: Winch recommendations / ideas?
K9Vic
Fort Worth, TX
I agree on the HF 12000lb winch as I have one on my M1031 and Suburban CUCV clone. I have pulled out a RAM 1500 from a ditch with my previous M1009 with no issues. You can usually get the 12k for $299 during the sidewalk sale, or a 20% coupon will get you close to that.
lostnbfe
Decatur, AL
I'm modeling mine after this guys setup. Even got the same Warn 9.5TI winch and Warn cradle. Not sure how he got his mounting points on the front and rear to line up. Mine have a 6" difference between the shackle points. So I will have to figure up a way to have them adjust. http://www.youtube.com/watch?v=flypFgBeg9w
richingalveston
120
galveston/Texas
He just thinks it will go on the back, he obviously has never tried to put it on the back. His mounts to the cradle were welded so no way it is interchangeable. It is a good setup for the front, for all the time spent on the mount, installing a front receiver would be just as easy.
richingalveston
120
galveston/Texas
Here is my setup for the front and will go to the back as soon as I get the rear receiver hitch.
If you can fab up the front cradle, you can do what I did.
The winch is a 12,000 lb mile marker.
edpdx
75
Oregon
Look around on this forum, seems there was a guy with a trick WARN that went in between and behind the front bumper mounts. He explained it pretty well IIRC. I've got that project on the short list. Just before #7: Add bottom thrusters from a Harrier Jet for easier parking, and those pesky gated roads during hunting season.:grin:
