M1009 wont crank when outside temp is hot and motor is cool from sitting all day
CUCVmike
Somewhere, TN
My M1009 the last few days when the temp. has been 89 and 91 degrees wont start after sitting in the sun all day while I'm at work. The motor won't crank at all and the engine is cold (90 degrees) from sitting all day, I don't think its a starter, ignition switch, or ignition lock cylinder as I replaced them a year ago and only have 2,000 miles usage since. I still had occasional issues after replacing them so I zip tied the wires tight on the ignition switch and made it all last summer with no more issues. If I have a bad wire would just the air temperature cause the ignition switch to not function? Not sure where to proceed in solving the problem, appreciate any advice or be glad to give any additional information I forgot to mention.
Warthog
227
OKC, OK
Please clarify.
It will not crank - engine does not turn at all
or
It will not start - engine cranks but will not fire. If it does crank, what is the speed? fast or slugish?
Just because a part is new does not mean that it isn't bad. Only way to know if a starter is good is to remove it and have it tested. Sadly bad parts from the factory seems to be the new norm.
CUCVmike
Somewhere, TN
This morning or late afternoon after the outside temp is cooled off, starts with no issues. It strictly is a hot and sunny temperature issue.
Barrman
1,655
Giddings, Texas
Does anything happen when you try? Such as the idiot lights changing, noises or clicking?
Also, turn on the headlights and try. If they don't dim, the problem is probably before the starter. If they dim, then it is probably starter related.
Of course, have you checked your batteries?
CUCVmike
Somewhere, TN
Yes, brand new batteries, been doing great the last month since rebuilding motor, then hot two days and nothing, outside temp cools off and its works again. Lights don't fliker.
