m1009 wont turn off
trooper632
Utopia, TX
last night when I turn the key to the off position on the m1009, nothing happened. I had to pull the pink wire on the injection pump to kill the engine. Also with the key in the off postition, the wait and gen 2 light stayed on, Is the ignition switch bad or what, I had to pull off the neg battery ground off the front battery for the gen 2 light to go out but when the cable was put back on the only light that still remains on is the wait to start light, the truck starts just fine but wont turn off, what gives
1,177
31. WILL NOT SHUT OFF USING KEY
NOTE
Ground wire for ignition switch goes to top of parking brake bracket. If
ground wire is broke, engine will not shut off if light switch is on.​
Step 1. With engine at idle, pinch flexible part of the fuel return line at fuel injector pump to​
stop engine. Notify your supervisor.
salt6
B'ville, OK
31. WILL NOT SHUT OFF USING KEY​
NOTE
This is how I had to stop my truck when I first fire it up. I cleaned the ground bracket and the clip on the end of the wire above the emergency brake and everything is working fine now. So follow the motto "clean it if it's eletrical" is good advice.
TarpleyJ
Central Louisiana
Could you add a picture of the location of the wire?
