M101 A1, A2 ,A3 Inside box dimensions
1,178
Please add your State to your location information. This is a site requirement.
Thank you
1,808
Inside length is exactly 8'. Overall inside width I don't remember but the width between the inner fenders is 45" on all but the A3 which is 55".
rdohara
Apple Valley, CA
Ok thank can you then tell me what makes them different from each other then besides the box size? My plans are to use one just as a utility trailer to pull behind my K5 blazer and put a dirt bike or 2 in it.
Nonotagain
41
Parkville, MD
I was wondering the inside demesions too then i see there rated for 3,000 lbs , to light for what i wanted .
If you need a heavier trailer, look no further than a M105.
They are rated to tow 1.5 tons, which is highly under rated.
The 105 trailer weighs 2700 lbs +/- a few lbs empty.
The 101 trailer weighs 1300 lbs empty.
Bob H
160
A1 no brakes, takes 5 lug military wheels
A2 surge brakes, civi 8 lug wheels (8 on 6 1/2 bc)
A3 surge brakes, crank up landing leg, 8 lug humvee wheels (wider axle w/more ground clearance) & wider fender flares.
the inside of my A1 box (on a A2 frame) is 95 3/4" with tailgate up
I pull my A2 with a Cherokee and my M880's
