M101 specs please
ccf460
granite falls/N.C.
I am looking at using a m105 or m101 bed for a project. I have the dimensions for a 105 (in my yard). But cant seem to find reliable measurements for a 101. I am looking for overall length, width, height. Also,most critical, measurement from front lip(forward most edge) to center of wheelwell opening, and inside to inside width between fenders. Thanks ahead. I am building a cucv clone out of a chevy k30 crew cab long bed 4wd, and would like to use a trailer bed.
KsM715
142
St George Ks
I got everything but the height (forgot that when I went outside, I'll get it in a few) Overall length is 99.5" (edge of front lip to outside edge of tailgate). Overall width is 73.5" outside edge to outside edge measured at the bottom front of the trailer bed. The inside measurement from wheelwell to wheelwell is 45.5" and the measurment from front lip to the center of the wheel opening is 56.25"
Height is 20" without bows and cover and 51" with.
Gunner USN
Minnesota
Google the following:
m1101 trailer specifications
m101 trailer specifications
m101a1 trailer specifications
m101a2 trailer specifications
m101a3 trailer specifications
Xfile
Sanford, FL
Here are the dimensions/specs for the M1101/M1102 trailers. They are wider than the 101 series. The information came from olive-drab.com. Hope this helps.
Maximum Vehicle WeightM1101: 3400 lb (1542 kg)
M1102: 4200 lb (1905 kg)
Curb Weight1460 lb ( 662 kg)
Maximum Payload CapacityM1101: 1940 lb (880 kg)
M1102: 2740 lb (1243 kg)
HullUnitized body construction using aircraft grade aluminum and chromoly steel
Overall Length132 inches (335cm)
Overall Width85.6 inches (217 cm)
Overall Height52.5 inches (133 cm)
Overall Height w/Soft Top Kit99.5 inches (253 cm)
Track Width72.5 inches (184 cm)
Drawbar Length93.2 inches (237 cm) (from axle center to eye center)
Drawbar Eye Height29.5 inches (75 cm)
Deck Height34.5 inches (88 cm)
Ground Clearance (Laden)16 inches (41 cm)
Suspension TypeFully independent progressive rate trailing arm suspension
AxleTubular steel
Spring MediaProgressive rate torselastic rubber chords
Shock AbsorbersTelescopic, direct acting, one per wheel, HMMWV compatible
Wheels16.5 X 8.25, two piece steel, HMMWV compatible, 8 on 6.5 inch bolt pattern
Tires37X12.50R16.5 Goodyear Wrangler M/T, with 30-mile runflat inserts, HMMWV compatible
Brakes12 inch x 2 inch free backing hydraulic surge brakes with automatic breakaway actuation. Independent lever-operated left and right side mechanical parking brakes.
Electrical System24 Volt DC sealed lighting system with blackout convoy lights, 12 pin connector plug mates with HMMWV
Max Speed (Primary Roads)55 mph (88 kph)
Max Speed (Secondary Roads)35 mph (56 kph)
Max Speed (Off Road)20 mph (32 kph)
Departure Angle39 degrees
Turning Angle80 degrees
Fording60 inches (152 cm)
