mine stuck all the time. I kept a 12 inch piece of 1/2 pipe in the truck so i could tap on the ip to shut it off. I have a rebuilt pump being installed now so i hope that stops it.
The 1 volt may be able to hold the swithc once it is engaged and since it is probably sticking some anyway. Run some two stroke thought it on the next few tanks. I put 1 quart in every tank on my truck once the problem started and it relieved the issue about %50 of the time. You have some transient voltage coming from somewhere in the electrical system. I do not know what kind of radios and other equipment you have but it could be an accessory device bleading voltage back to your grounds or fuse panel. If you have a bunch of accessories, start pulling fuses on them one by one and see if it gets rid of the 1 volt. Alternator diode may be going also.
The valve can stick with no power so one volt can make it stay open, it will start sticking and get worse without some lube. I think it is just an age thing with the IP's my last 1009 did it on occasion also.
