lavarok
- 34
- 48
- Fellsmere, FL
So, in an effort to get my "surgical" dome light working in my M1010; I spent some time pouring over the circuit diagram in the back of my truck.
I need help from someone who has removed the interior panels and/or seen the insides of a M1010 box without the interior skin. I am trying to locate the splices and wire harness marked in red on the attached jpeg.
The "BO RELAY SW" is on the driver side fuse/power panel in the rear of the box. These splices and wire harness are somewhere behind the panels. I am guessing front driver side, but I'd rather KNOW and not guess since it will require drilling of several rivets to remove the panel.
My focus lights work, so I know its not a relay or lack of power issue. When I check for power at the front dome light switch, there is none. The dark blue wire should be 'hot'.
Help!
Help!
