M1010 stuck in the mud.
uscgmatt
13
Cordova, Alaska
Went to go pull out another vehicle, an f-150. Lets just say nothing went as planned. We ended up using a 9000 lb winch on a wrangler to pull out both trucks, after we strapped it to a tree. Its time for some new tires and a winch. On another note is the locker in the rear supposed to spin both tires the same speed? One was spinning fast and the other really slow.
Matt
Dabba
Long Island, New York
man o man. Yeah, heavy truck in the mud =bad. And yeah id get that locker looked at, i would think both would always spin the same speed with your foot on the gas
uscgmatt
13
Cordova, Alaska
The mud there reminds me of muskeg in Alaska. When I was driving in it looked like a plain grass trail. The first ten feet was hard so I went back in the truck and started driving. Then I found a soft spot and down it went. The severe muddiness is from a thousand foot prints.
Matt
1,124
I love playing in the dark.
SR71BLACKBIRD
Galion, Ohio
I found if you are going to be the guy everyone comes to when thet are stuck, Best buy a good winch.
This milemarker(hydraulic) would pull out a deuce if you tie to a tree.
I've got one of those hydraulics also. I rigged mine for use on my compact tractor. Special valve to keep the pressure right, special valve to choose between the tractor or winch having hydraulic power. That winch skids trees just fine, and pulled me out of a few beaver ponds I was ripping dams out of. I had to give that up, hydraulic fluid, rebuilt the starter, draining the clutch housing, it all gets old.
OLDCHEV4X4
Glenmoore PA
Dosen't the 1010 have a posi front axle?
Yea, i would deffinately pull the cover off the rear and have a look. They should pull the same speed when stuck.
Its nice to have all those lights for night time opp's.
1,814
Looks like a fun recovery. Perhaps some bigger iron in your motorpool is in order. The coolest part of all the pics is the light. Love having the work lights on the side and seeing the copious amount of light in the back is awesome.
