M101A1 hub/bearing help
warwick
Maryland, USA
i got a m101a1 from govliq... finally got around to packing the bearings and hubs w/ fresh grease today... there was no seal or silicone and hardly any grease... mostly just rust.
anyway the inner bearing is rusted to the spindle. i can't get to the lock ring and i cant get the bearing to move.
any thoughts on how to get the hub off?
McGuyver
Utah
So are you saying that the inner race of the bearing is seized onto the spindle? Here's a little trick I've tried before when I had a situation like this. Take a die grinder and cut the bearing race until it's almost cut through to the spindle underneath. Then take a chisel and wack it in the cut until is splits. From there, it will either spring open enough to get it of the spindle, or you can peel it off. Hope this helps. Good luck.
edit: I just reread your post, and it sounds like you haven't even been able to get the hub off yet. Is this right? If that's the case, then what I just detailed above won't help you any. Maybe you could some how cut the lock ring off first and then work on removing the inner race of the bearing, as I described. It may also be easier to work on all this if you remove the brake drum from the hub first.... just a though. Good luck!
warwick
Maryland, USA
... should have been more clear on what i have
the hub and drum are still on the spindle and the inner bearing is rusted to the spindle
if the hub was like a m715 hub i could get the hub/drum off by persuading the seal out with a BFH and/or crowbar
but the m101a1 hub has a lock ring to keep the seal and inner bearing in
round two monday afternoon...
McGuyver
Utah
Gotcha. Yeah I forgot about the snap ring. I see what you mean, that is a problem. You know, maybe you could remove the drum (two slotted screws retain the drum on the hub), then pry the hub off (with much persuasion.) You'll probably ruin the bearing in the process, tearing the cage apart and scattering the rollers everywhere at the same time. But once you get the hub off, you could use the method I outlined previously to remove the inner race from the spindle.
There is some hazard in this approach though: you could damage the snap ring or hub casting in the process of prying the hub off. Just be aware of the risk.
warwick
Maryland, USA
got the hub/drum off today... i bolted a length of chain to the hub and used a pipe as a handle... i yanked on the chain 6-7 times and the rust let go
hope the other side is in better shape
McGuyver
Utah
So did the bearing inner race come out with it, or did you tear the bearing apart in the process? Glad to hear you're making some progress.
warwick
Maryland, USA
got the bearing and race off with out destroying them, however they are pretty trashed from not having any grease. I'm going to replace them all, checking prices and availability now.
devilman96
17
Boca Raton, FL
Guys with Warwick's help I was able to track down the seals and bearings which I am now listing in the store... Thanks for numbers!!
EDIT: No longer a valid link
devilman96
17
Boca Raton, FL
Hey if you need it and I dont have it please ASK especally if its a high wear /PM type item!!! ... This is how I usually end up adding most of my new stuff to the store. Sometimes it takes days... others it takes MONTHS!!!... But I will usually go chase stuff down for the simple reason of I know its needed...
Not to mention... It motovates my lazy butt!
juanprado
3,175
Metairie/La (N'awlins)
Thanks to warwick as I had the same problem. The hub has 2 nice 3/8 coarse unused bolt holes. I threaded a bolt through a double linked chain on both ends to make a pulling handle. Used a rock bar and pried it off easypeazy.
Replacement inner hub seal in civy numbers is a C/R or SKF 28116 or a National 417485 to replace nsn 5330-00-154-8353 part # 55010
The original one was a trostel 356-252-75
The outer hub plate 6 bolt gasket is a felpro 4390 , OE Chrysler # 915565
