M101a1 trailer lug bolt threads
1,806
Look for other indicators as well. I've encountered swapped hubs and even a mix of studs on one hub. Seems to me have one odd stud on every wheel could confuse a would be tire thief. We all know that NDTs are high on a thief's list
Slhadley
Bothell/wa
Thanks - so if I understand my right from left, to remove the bolts on the driver side, I will need to loosen those bolts "backwards"
mrfishaholic
Olympia, Washington
it is that way on 80's ford 1 ton pickup trucks too, ask Les Schuab how they know...... (had to replace all the studs on the drivers side of the truck cause they torqued the **** out of them and had to replace a set of wheels too.... tough learning lesson....:driver:
