M101A2 -->36" Tires
Nico
15
Germany, Hamburg
does anybody know, if 36" humvee tires on dodge 16.5 8lug rim`s will fit to a M101A2 trailer?
(m101A3`s are hard to get over here.)
thx
nico
4,756
Dodge uses the same lug pattern, so as long as the wheel width and backspacing are ok, it should work.
blybrook
Fairbanks, AK
Hooty, the bolt pattern is the same. However, the Ford pattern changed in late '97, early '98 to a metric bolt pattern. You'll need pre '97 Ford rims to get the proper bolt spacing. Some will say that you can go to a '99, but I've tried '98's and they won't work. The Fords have a larger center hole, it is not hub centric like the Chevy rims.
Bob H
159
All Older Gm, Ford, Dodge, all were 8 on 6.5 the hub hole is bigger on the Ford and Dodge.
Your 16.5 tires will work, "NO SAFETY BEAD 0n 16.5 rims"
Here is a big tire on a trailer to see fitment.
on MOST 16.5" rims and all M880 rims, I have a couple sets wth the bead.
what about the m101a1 its a 5 lug will a stock civi wheel fit that ?
yes, an old school civi powerwagon wheel.
Nico
15
Germany, Hamburg
thx 4 the info!
ill try to get some dodge rim`s
good to know there is no problem with the space between the 36"tires and the fender.
:beer:prost!
