connectingbar
- 3
- 18
- New Hartford, NY
I have a nice set of shoes off a 101a1 if you need them . Just pay shipping
I used some HD wheel bearing grease from the local supply house. They have disk or drum brake versions, IIRC, I use disk for everything; one less container to keep around.What is the best commercially available wheel bearing grease for the M101s? The TM shows automotive/artillery grease...
I went shopping for bearing packing/replacement stuff for the trailers. I picked up:
HF Bearing Race and Seal Installation Kit for $32
Lisle Handy Packer for 3 1/2" Bearings for $24
3/16" x 2" cotter pins for $2
Mobil 1 sythetic grease already in the garage
1 1/2" socket 1/2"drive for $7
I know a lot of you can do this by feel, but I haven't got that touch. I did one trailer and had a hot hub and a cool hub after following the TM. I tore the hot hub down, checked for heat damage, and repacked both bearings with the handy packer. After reassembling the hub, I followed the TM, retorqued to 30 ft/lbs, and then backed off the axle nut -- plus a bit more, eased it back to a stop and pinned it. There was no slop.
I took the trailer out for a 5 mile spin and came back with 2 cool hubs. I'm going to keep an eye on the Mobil 1 sythetic grease, and if I need to, I'll repack with new HD grease.
Time to get some firewood.
I know this is way after the fact, but is there any chance you know that part # for the napa slave cylinder?I just finished my M116A2 and here are some useful NAPA numbers:
Axle Seal 22532
Bearing/Race BR25580/BR25520
Flexible Brake Hose 5784
Slave cylinder overhaul kit 264
Master cylinder overhaul kit 137
Napa also carries the entire slave cylinder but its more expensive than etrailers.com
View attachment 437041 View attachment 437042 View attachment 437048
Al Jones
Brookings, SD
