M101A2 Axle Bearing and brake questions
Firehound
102
New Caney, TX
Howdy!
I've got a 1983 M101A2 that has a bearing that gets uncomfortably warm after a few miles. Where would I begin to look at finding a new set of bearings? Anyone have the tech pubs on how to perform the change?
Also, I've heard tell that the M101A2 has surge brakes, but as best as I can tell mine just has break-away brakes. How do you tell what you really have and how do you tell if it's working properly?
Thanks y'all!
Westech
CPL
6,104
206
cow farts, Wisconsin
I would take them out and check them out/service before I would just say there junk.
It is VERY simple to take them out and do the service. You should not need a manual to do wheel bearings on a dead axle.
As the brakes goes do the brakes come on when trying to back up? It should be a ez tell to see if you have surge brakes or not by the action of the lunet.
Firehound
102
New Caney, TX
I dont feel the surge brakes come on when in reverse, but the unit DOES have brakes beyond the parking breaks. There is a hydraulic line running to the hitch and a break-away activation lever. Is it possible to just have the brake-away, or is the system completely inop?
Mistaken1 Thanks for the manual!!! I'm a former Jayhawk Avionics tech, and I currently work on Chinooks... I was hoping to run across a M101 manual that I knew how to read!
412
17
Lutherville, MD
You probably need to adjust the brake shoes. I have had to do that on several.
