yellowrubicon
- 2
- 0
- Montpelier, VA
Since I couldn't find the information here I thought I would share what I found out to work.
For the surge brake master cylinder use Dorman part number M2796. ABOUT $41 on Amazon.
For the flex line running from the frame to the rear axle use Dorman part number H36965. About $13 on Amazon.
For the brake lines running from the center of the axle out to each wheel cylinder of the axle, get two 3/16 lines each 31 inches long with the fittings already in place. Make sure it is SAE threads. Bend the new lines similarly to the existing lines. Use a 3/8 flare nut wrench for the ends of the brake lines. A standard 3/8 wrench will work but the fittings are brass and prone to rounding off if you put to much torque on them.
Hope this helps someone else.
