M101A2 Brake parts and part numbers here
yellowrubicon
Montpelier, VA
Since I couldn't find the information here I thought I would share what I found out to work.
For the surge brake master cylinder use Dorman part number M2796. ABOUT $41 on Amazon.
For the flex line running from the frame to the rear axle use Dorman part number H36965. About $13 on Amazon.
For the brake lines running from the center of the axle out to each wheel cylinder of the axle, get two 3/16 lines each 31 inches long with the fittings already in place. Make sure it is SAE threads. Bend the new lines similarly to the existing lines. Use a 3/8 flare nut wrench for the ends of the brake lines. A standard 3/8 wrench will work but the fittings are brass and prone to rounding off if you put to much torque on them.
Hope this helps someone else.
Tinstar
2,569
East of Edmond, Oklahoma
The part numbers for those, and other brake/Axle/wheel components, have been posted many times.
They are all still readily available from different manufacturers.
A thorough search would have revealed that.
Dorman is a lower quality part.
Buy the best parts you can afford.
You do get what you pay for.
doghead
4 Star General /Moderator
1,193
NY
I just did a search(on this site) for both of those numbers (dorman xxxxx) and found nothing.
  • Like
Reactions: art
Tinstar
2,569
Ok.....and?
The replacement parts for these trailers have been posted in different threads over a dozen times.
I know because I've read all the old threads. Every single one.
The Dorman number didn't show up in your search. It will now since he's posted it.
Most guys stay away from Dorman
A search with other keywords would have pointed to threads with that info,......but you already knew that and wanted to make some point here.
Your usually the first one to say SEARCH!!!
doghead
1,193
NY
I agree about searching before posting.
My point is, the numbers he posted with the term dorman, do not come up in a search.
If I were to post, the manufacturers name and part number would be the most important things to post for others to find the parts in the future.
Again, nothing came up. Either everyone else posted in incorrect format, or he has. I did not add dashes or spaces to try other options.
yellowrubicon
Montpelier, VA
Sure they are on here but searching for “m101a2 brake parts“ turns up a bunch of posts that are very verbose and not concise. Plus, most posts point to etrailer or some other over priced site for parts. It's just a trailer, not a palace on wheels. I'll take the low cost parts.
Tinstar
2,569
I agree some things don't need the top of the line parts.
However, brake parts, no matter what it's on, get the best parts I can afford.
I never know what I will be hauling and want the brakes to work every time, all the time.
Lifetime warranty means nothing if I have to replace the same part 3 times in a year. Or worse it fails at a critical moment.
Buy OEM or equivalent and it will last for years.
I personally stay far away from Dorman and according to other threads, most other guys do also.
In parts, you usually get what you pay for.
Of course your trailer and install what you want.
art
30
Northern N.J.
How about a sticky thread on M101 Trailer replacement parts?
So we don’t have to search for hours and people don’t have to ask the same parts questions and get scolded at.
On same line as the key for a CUCV :deadhorse: (which is a sticky)
Thanks!
Tinstar
2,569
There is one for the brake shoes and bearings.
Another for the brake levers.
Those are the most commonly requested part numbers.
