M101A2 Spare Tire Mount/Carrier
JohnnyP11B
Texas
Good morning all -
I am trying to find a mounting solution for my M101A2 spare tires (235/85/16) mounted on 8 lug Dodge rims.
Most everything I’ve found is designed for 4 or 5 lug tires.
Any suggestions?
juanprado
2,899
Metairie/La (N'awlins)
I simply have mine standing upright in the back facing the side inbetween the wheel well and back with a ratchet strap to the side and through the tire. Takes up minimal space.
Others have used tire winch mounts from pick ups or suv's and made a frame underneath to hold it under the bed and winch down when needed like my Durango or Tahoe use the same system. Easy to pull from a junkyard for minimal $
PsycoBob
11
Auburn, NY
Bit of a necro-post, but I found a RV trailer tire mount/hoist, designed to adjust for different frame width. Amazon shows it as unavailable sometimes, but the idea is good.
MarkM
CODE BROWN...It's all going to sh~t !
1,966
WOBURN. MA.
If you can find the spare carrier from the M37 you will be all set. I have one and it works great.
Mark
