chevymike
- 485
- 63
- San Diego, CA
Very cool but I was definitely expecting more HP. Seems like a lot of money and work to get 215 HP. Still cool though.
There is more indeed, and in my case we have choosen the safe side. The IP is calibrated to 215bhp. I'd like to keep the standard crankshaft and don't want to upgrade the 4l80e at this moment.Very cool but I was definitely expecting more HP. Seems like a lot of money and work to get 215 HP. Still cool though.![]()
I'll make a couple of pictures of the results later today.Interesting. 250 Hp you say? Any other numbers? I am curious on manifold pressure. With a centrifugal compressor, I would assume this pressure is at high engine speed.
Positive displacement blowers tend to give boost to compensate volumetric efficiency losses, centrifugal boost higher engine speeds.
252Bhp sounds great!The engine is back home again. It was brought this morning and I will make more pictures tomorrow so you can also see more details.
They have also played with a different pulley this week to see what happens.
Well, it gave 252bhp! Nothing wrong with that I think so
The computer showed the torque output was not steady and the reason for that is a fuel shortage. As mentioned before, the IP is calibrated on the safe side.
For now we leave it at is because I'd like to get the truck running and moving again.
We can always take the IP out again on a later moment.
Next upgrade will probably be an upgrade to a 8hp belt. The only thing we can't find is an 8rib steeringpump pulley. Does someone know where to get one?
Fuel shortage? Which injection pump are you running? In order to feed a fuel supply to satisfy 250 HP you may need to consider a marine pump. A 250 HP fuel supply will be at the top end of the OEM pump's capabilities. In fact I am not sure you can get that much fuel out of an OEM pump. For my Bullet supercharger project, I am having Huckstorf Diesel build me a marine pump with 33mm plunger and rotary head. The later DB2 pumps are the only ones which will accomodate this fuel supply. Pumps with the last 4 digits of 4911, 4927, 4970, 4971, 5079, 5088, 5089, 5119, 5129, 5149, 5157, 5164, 5167, 5209, 5223, 5436, 5437, 5438, and 5485 will all accomodate the 33mm plunger and rotary head. A marine pump with 33mm plunger and head will provide a fuel flow to satisfy 250 HP with the adjustment screw set at approximately half-way. Which means you can turn it up a little more, or turn it down a little based on how the engine is performing. You should also install marine injectors as well, which pop at a higher pressure and deliver more fuel.The computer showed the torque output was not steady and the reason for that is a fuel shortage.
Thanks for your advise and information.Fuel shortage? Which injection pump are you running? In order to feed a fuel supply to satisfy 250 HP you may need to consider a marine pump. A 250 HP fuel supply will be at the top end of the OEM pump's capabilities. In fact I am not sure you can get that much fuel out of an OEM pump. For my Bullet supercharger project, I am having Huckstorf Diesel build me a marine pump with 33mm plunger and rotary head. The later DB2 pumps are the only ones which will accomodate this fuel supply. Pumps with the last 4 digits of 4911, 4927, 4970, 4971, 5079, 5088, 5089, 5119, 5129, 5149, 5157, 5164, 5167, 5209, 5223, 5436, 5437, 5438, and 5485 will all accomodate the 33mm plunger and rotary head. A marine pump with 33mm plunger and head will provide a fuel flow to satisfy 250 HP with the adjustment screw set at approximately half-way. Which means you can turn it up a little more, or turn it down a little based on how the engine is performing. You should also install marine injectors as well, which pop at a higher pressure and deliver more fuel.
I also recommend that you install a mechanical fuel pressure gauge immediately upstream from the IP to make sure your lift pump is supplying adequate fuel at the point of requirement. Remember to also install the isolator under the hood to keep fuel out of the cab.
Hope this helps. Your engine looks fantastic. Looking forward to a video with it running in your truck.
This is the fuel pressure gauge I am installing - https://www.autometer.com/2-5-8-fuel-press-0-15-psi-w-iso-mech.htmlThanks for your advise and information.
I'll check the numbers again tomorrow. I have forgotten them. I do know it's not an 833 and I thought it is a 4911.
The pump is a rebuild and calibrated on a bench to make sure it delivers enough fuel at various rpm's.
I have got marine injectors from quad tuning. 4 of them leaked while sold as new. So they have all been checked again. I have been told you could beter use the stock nozle because it has a better spray pattern. The marine nozles squirt to one side. Only they will never have problems with clogging up because of the bigger outlet and form. He normally upgrades the stock injectors to a higher output and more pressure to pop. I thought to 140bar instead of 110. (If I remember correctly) also the standard pattern keeps the cilinders at a lower temperature.
I will check the options for a fuel pressure gauge! If you have a recommodation, let me know!
Thanks for the gauge. I have to check if the one I bought is also able to show the fuel pressure. Otherwise I use yours as a refference.This is the fuel pressure gauge I am installing - https://www.autometer.com/2-5-8-fuel-press-0-15-psi-w-iso-mech.html
Regarding the marine injectors having an inferior spray pattern, squirting to one side, clogging up, yada yada yada. It sounds to me like somebody is wanting to sell you stock injectors. I know for a fact that the only difference between the two is the pop pressure and quantity of fuel delivered. Marine injectors are going in my P400.
The block has been checked and also the heads are checked with dye penetrant.Studs are an engineers decision, bolts an account's. Don't just replace, head gaskets are wear items as father time erodes precious sealing materials.
When the block is decapitated, it's a good idea to check for any cracks, dye penetrant exam is quick and cheap. Definitely a DIY option. Also check deck and head flatness.
The times are a changing...Diesels do not need BOV as there is no throttle.
