M1028 from Hell finally home!
JohnFire
Pottsville, PA
I too have looked at the dakota gauge setup but the $600 price tag is really keeping me from doing it. plus I would want to add the cruise control on it as well
AJMBLAZER
Paducah, KY
I like that it has the speedo adjustments built in. That's over $150 to fix it at the transfer case so I figure that makes it a $450 or less gauge cluster. Start pricing gauges and you'll see the Dakota setup gets affordable really quick.
hndrsonj
Senior Chief/Moderator
368
Cheyenne, WY
Wasn't that truck rolled in Atlanta while on a trailer last year? Guy wanted like 2700$ for it? The silverado cab will probably have air will create issues. Hawthorne tractor in Lake City had a couple nice cabs for sale.
CCATLETT1984
Saint Clair Shores, MI
I got the gearbox to correct mine for $68 including shipping.
AJMBLAZER
Paducah, KY
Just to update I emailed Dakota Digital and asked some questions about their dash and diesels.
-It can be used with diesels and does have a WAIT TO START light option.
-The diesel tach would require one of two pickups, either from THE alternator or in the bellhousing off of the flywheel. Alternator sounds easiest but then we have two and a 24 volt system...can we work around that?
-GEN 1 GEN 2 lights not sure, sounds like their setup is meant to just read the volts in the system as it's meant for single alternator setups.
mangus580
283
Western NY
Cool!!
It can run off of ONE of the alternators, and will do exactly what you need.
Maybe they could just make it so it reads the 24v range? The idiot lights arent really needed if you have a good volt meter... It will tell you right away if one quits.
AJMBLAZER
Paducah, KY
Yeah. I'm just sort of researching it now. Barring some failure of my dash and gauges this is a good ways off...but I like that it fixes the speedo and odo and has all the nice features all in one. This post just got me thinking about it now.
I'll have to ask him about the 24 volt thing. I can't see why it couldn't read it unless their system can't handle the power. Which I doubt. Seems like it should be able to do it.
A nice classic looking dash with the correct gauges would be good but oy, ever tried to find a factory large tach, small fuel gauge, and good working gauges?
JohnFire
Pottsville, PA
I personally am waiting for my speedometer to blow up. When it is cold out it makes a terrible noise and spins way tooo fast ie: saying I am doing 90+ when I might be doing 45-50. Once it warms up it goes back to normal. I have already converted the truck to 12V so that is no biggie to me. Plus I want to tie in their cruise control if I do replace the whole thing.
mangus580
283
Western NY
Interesting... mine does the same thing!
JohnFire
Pottsville, PA
Sounds like the thing is going to spin out of the dash. I wonder what our problem is with them. Besides the annoying racket it definately adds extra miles. When I first got the 1009 it made a similar noise and the then I had no speedometer till I replaced the gear on the transfer case but it wasn't the cold. It seams odd to me that all it has to do is warm up after about 5-8 miles driving.
AJMBLAZER
Paducah, KY
The speedo cable needs to be lubed. Pull it out of the gauge and put some good, non-disapating (sp?) lube in (as in not WD-40 etc) down it. If you're lucky it's okay and just slow on lube. Long term it can screw up the cable and the gauge if not lubed.
This happend on my Tracker and it took the cluster with it. Whoops.
