M1028 Gen 1 Issue
Unclewally
Saint Augusta, MN
I've been trying to figure this out by looking at the TM's and Parts Diagrams, but I have been unsuccessful so far.
I have an M1028. It was not heating, and I diagnosed it to need head gaskets. It took several weeks, but I finally got it back together after 3+ weeks. As it always seams, whenever you finish a project that are left over parts. 2 bolts and 1 wire (maybe 8" long - looks to be a ground).
I had some help with dissassembly, so I'm pretty sure I did not remove the wire. I'm usually good at remembering where everything came from, but at my age, I might be losing it a little.
Anywho...
The Gen 1 light will not come on. The truck would start and run fine, so I didn't think anything of it at first (this is my first Gen problem that I've had with this truck - lucky I guess).
After reading through a ton of stuff, I believe this 8" long black wire belongs on the ground side of the drivers side alternator (small stud on alternator to ground on the engine).
Can anyone verify this to be correct?
I will check some other things when I get it back home tonight and into the heated shop.
Thanks in advance,
Brian
cucvrus
10,505
Jonestown Pennsylvania
The left over wire is the isolated ground wire from the left Gen 1 alternator. It is bolted on back of the alternator ground stud and runs to the intake stud in the cross over for the thermostat. Check it out and report back.
cucvrus
10,505
Should be an M6 stud with a nut on back of the alternator. I use a battery cable when I replace mine. I do excessive grounding. It helps. I bought a truck that had electrical issues and would not start. I replaced the starter and it still did nothing. It had the ground cable missing from the engine and had melted the light braided ground wire on the right back side of the engine. I never realized how well isolated the engine is in a vehicle. I seen a few guys hook the ground clamp on the tail pipe to weld on the frame. Poor results happened. Good Luck. Happy Holidays. Looking forward to a positive report.
Unclewally
Saint Augusta, MN
That was exactly the problem....
Five minutes to put the wire in. Jump the front batt, and walla!
Charged the battery overnight and it works like a champ....
thanks!
