Swfb
- 99
- 18
- Netherlands
During the anual check my m1028 did not pass the brake test.
The difference in brake force, between the left and right rear wheel, is about 50%.
2 years ago I did not had this problem.
And no parts had been replaced between both checks.
I can't seem to find what is causing this problem so I hope one of you can help me.
What I have done so far:
- Adjusted the brakes as mentioned in the TM.
- Switched drums from sides
- replaced brake pads
- replaced brake cilinders
- replaced springs
- cleaned all internal brake parts
- replaced parking brake cable
- replaced brake hose
- new brake lines from under the cab till both wheels
- old brake balance (load regulated) removed
- put in a new adjuster
- replaced proportioning valve
- new steering gear
- other power steering pump
Between installing and replacing the parts I have had the brakes tested multiple times.
It does not make any difference, it is still around the 50%.
And it's always the driver side that is failing.
What could cause this brake failure?
Brake booster?
Master cilinder?
- replaced springs
- new steering gear
Brake booster?
Master cilinder?
