Yeah I am running the Skyjacker one which is the one they sell at ORD. Skyjacker Pitman Arm CA50 Steel, Chevy, GMC, SUV/Pickup, with Power Steering, 2.5 to 4 in. Lift, 2in drop. I went out and looked at my v-3500 4” lift Big Block and my draglink is at a light angle, eye balling it I would guess it’s about an 1”-2” difference it’s hard to tell without getting a level with the tire in the way. I do need to adjust my drag link on my v-3500 as the steering wheel isn’t level and it doesn’t go to the steering stop in one direction but it was out of adjustment when I got the truck before the lift its just worse now, I would have done it already but I don’t drive the truck much as it needs tires and I have too many projects that need time $$, anyway I compared it to a couple other trucks here the stock k-30 with big block is pretty much flat and the v-2500 suburban has a slight angle with a small block. It’s best to be as close to level as possible but mine steers like stock other than the above mentioned needed adjustment. Here’s a pic:
