ehuppert
- 143
- 43
- Upstate NY
In the middle of a frame off (well, different frame) thrash and finally getting to the point where I've got stuff painted and trying to reassemble!
Way back when i parted out a C30 and used the frame perches and overload spring for my 1008. Overload springs were a double setup vs, the normal single spring. Well, they were rusty and crappy and both bottom springs broke so i got new ones from the place i routinely use and trust. (ATS Spring). Well, the old springs i had pirated from the C30 must have had more arch! Springs i have about 4" of arch which i referenced with some other suppliers and seem correct. Of course they're now painted!
My center block is about an inch thick... Truck is supported under axle (diff not hanging) on blocks and a set of "skates"
Does this look right? Hoping i put the old springs in the scrap pile at work so i can compare arch!
Realize no weight on back (bed off) will skew things, but seems like a lot more gap than before?
Thanks, Eric
Thanks, Eric
