M1028A1 Trailer Hitch question
chesapeake
Winston, Ga
I have read countless threads on adding a trailer hitch to these trucks. I have narrowed it down between two. Curt 14082 and the Reese 51016. The Curt will take a little work to put on and it comes welded together. The Reese, I believe takes no modifications to put on, put is put together with bolts.
I know it will be all opinions, but is one better than another?
Ted
1StumpJumper
NW Washington
I put a Curt 14082 on the rear of my M1008 as well as a Warn 25855 front hitch. A little bit of a PITA, but well worth it on both ends. Just plan on replacing all the bumper bolts and you will have a head start.
Drock
12
Eatonton GA
Any hitch you try and install on these trucks is going to require notching the factory brackets. It's just the nature of the beast. That being said you mite as well go with the strongest one you can find. I went with the (B&W 25122) it has a 16000 tongue weight.Reciever hitch.jpg
MarcusOReallyus
815
Virginia
Noo so, Good Sir Drock!
Member skysix has figured out how to do it with no notching required. It does require a few spacers and a custom U-bolt, but it's not expensive, and sure beats cutting things. Looks to me like a very nice setup.
Check it out.
This is the way I'll be going when I get one of those Round Tuits.
chesapeake
Winston, Ga
I went with the Curt. It required a little notching on the brackets for the D rings and I had to remove the spare tire carrier. I have a friend with a trailer shop who put mine own while I was at work. When I was discussing hitches with him, he advised me to stay way from the three piece hitches. That is the only reason I didn't do skysix's hitche.
