Skinny
- 488
- 83
- Portsmouth, NH
So my left over M1010 accessory brackets got put to work on my generator truck. I did a 12v conversion at the same time bit could have stayed 24v just by adding a second alternator. I absolutely disliked the aftermarket bracket solutions for the normal CUCV alternators. This is why I went with the M1010 setup. Could have been more streamlined with an in dash evaporator but I didn't want to do that either.
Got the Leece Neville triple 5 JHO doing 160 amps worth of work. The factory A6 compressor would have been fine but it weighs about 400 pounds and they notoriously leak from the crank seal. So I found a modern Sanden in the same shape as the A6 so it drops in. You could do like a 508 with adapter brackets but for not much more money I just bought a whole new compressor that fits.
Up next an eBay AC kit with a vertical backhoe cab evaporator. Had to use my ambulance buckets so it fits on the back of the cab. Overall very happy with the fit and it blows ice cubes right at my face.
It has a large universal cross flow condensor that I mounted using rubber standoffs and some aluminum strips which also hold the fans.
I probably have $1500 in everything including the hose crimper. Aside from excessive noise, smells, and rpms at cruise speed...the old CUCV is now a pleasure to drive in boiling summer heat. Plus in the winter my unit has an auxiliary heater as well.
Next project is to get a Webasto air heater in the Dante's Peak Suburban for winter camping.
Sent from my Moto G (5) Plus using Tapatalk
