M1031 generator
onotafire
Michigan
Was wondering if anyone knew the status of the training manuals (TM 9-4940-562-13
& TM 9-4940-562-23P) for the M1031 - we've been trying to get copies of them for a few years. Our fire department received one of these trucks via surplus from a state agency - but we haven't been able to use the generator due to lack of info on it. It's been pretty frustrating to try to find.
We use the truck for (mostly highway) rescue operations - it carries medical equipment, hydraulic tools for cutting cars, scene lights, etc.
I also appreciate everyone on here for providing all kinds of info - this site is a great resource.
onotafire
Michigan
Thank you, I was able to get the dyna manual - unfortunately the other one tells me that the links are inactive / the files were deleted.
onotafire
Michigan
Need some more help with our Gen. Everything is military original. We can engage the PTO, PTO light is normal. This is what happens, I engage PTO, run the throttle up, switch on the governor circuit. I get about 10 seconds of throttling then it drops to idle. I check the outlets with a meter, no output. On the governor controls, in the firsts compartment, there is a momentary switch, that when pushed provides a measured amount of throttle. What is this for? I do get outputs volts, (5v) on the one larger single phase outlet. I push the above mentioned button, and as the truck revs up, the main breaker kicks out. Any ideas or thoughts? Do I have a bad breaker, or is the governor control fouled up? I get no reading on the hour meter or the Htz. gauge.
NDT
7,499
Camp Wood/LC, TX
Please contact member here "b4thundr", he has an updated governor controller for sale. The stock setup is as you have found, completely unreliable. More info on your truck can be found by searching "SECM". I can tell you that the controller wiring and the 3 phase power wiring is completely independent. If you rev the engine to about 1200 rpm, you should get a proper reading on the HZ and volts gauges.
