M104 trailer for my M923a2 question
Snowtiger
British Columbia
I hope this is the correct place for this question, I have an opportunity to purchase an m104 trailer. Is the M104 trailer a good match to pull behind my m923a2 is from the Canadian forces and is in perfect shape it's the one made by manac. Is the plug in from the trailer to the truck wired to the trucks wiring and will it sit level to the truck. Anyone by chance have a picture of this type of setup and any recommendations for this combination, is it a good match or no. Thanks for any feedback or tips on this.
someoldmoose
Lancaster, PA
Should work just fine if both are "as issued". I don't have any pics but there are many on here I am sure. The only "height" issue would occur if the stock wheels and tires on either the truck or trailer, or both were changed. If the truck has 395 tires or bigger the trailer will not sit level with stock 9.00 20's on it. Easy fix.
98G
Former SSG
4,012
An m923A2 has 14.00R20 tires.
I've towed as small as am M101 behind a 5ton, and as large (and unwieldy and impossible to back) as an M989A1.
The little trailers are hard to see. I find M1082s to be ideal...
