M105 A2 Axle
shrevestang
I was just given a m 105 a2, i was going to change out the axel and put a drop axel on it so i can use it as an untility trailer, but i was wondering if any body knows if there is some sort of adapter that i can but on the existing axel so i can put standard size tires on it without changing out the entire axle. If so where can i go to look for it. Thanks
comdiver
Buffalo NY
They are heavy! They weigh about 2700lbs. You will need brakes. If you are towing with a deuce you can just connect the air line for the brakes. If I was going to tow with a p/up I think I would look at mobil home axles with elec brakes. Keeping the old springs you may need to fab spring perches. Make certain the tires will handle the load.
shrevestang
I found a 5200lb drop axel with electric breaks for around $300 and the tires and rims for about another $250. I was just trying to see if i could find some smaller tires and rims for that existing axel first.
