M105 and M101 plug wire swap
joshs1ofakindxj
118
SW PA
Do the M105 and M101 share a common trailer wire from the chassis connections to the truck plug?
I'm fixing up my 105 and I purchased a 101 cable and it seems to be about a foot or so shorter. When I loop it through the hand loop by the pintle hitch it won't reach back to the u-bolt where it rests.
Doh!
1,806
As you have found, there is a length difference. The M105 has a junction under the front of the trailer box where the M101 has the junction on the tongue leg which uses the shorter cable.
3dAngus
101
Perry, Ga.
You can use the M105 cable on the M101, but if used the other way around, due to that shorter length difference, you might have to reroute the entire cable underneath to make it reach. I haven't tried it, but looking at my two different trailers, it looks like it might be possible by disconnecting it all from front to back, and redoing it straight to the pintle area with tie wraps. Let us know what happens.
joshs1ofakindxj
118
SW PA
I'm going to post a wanted ad for the right cable if I don't have a spare on my 103 sitting out behind the garage I can steal.
