M105 Trailer wiring & build 24v to 12v 4 or 7 pin connection
1,181
I posted bulb numbers in the other thread you cross posted into.
You'll need to test the wires to figure them out. I do not believe there is a color coded chart for trailer wiring.
Why are you using a 7 flat plug(never heard of one)?
Mike of Bonsall
Bonsall California
By 7-flat I mean the standard civilian truck round 7 receptacle. Flat I referred to the shape of the pins not being round. Can't think of its right name, sorry again. Anyway trial and error easy enough to do. Thanks.
1,181
I think it's called a 7 pin or pole RV plug.
I was confused.
Thanks for the reply.
LanceRobson
206
Pinnacle, Stokes County, NC
This has been a good use of an old thread instead of starting a new one. Just a few notes on modifying the trailer...
While the nominal cargo weight of an M105 is 1-1/2 tons it is worth noting that current publications make it clear that the rating is "for severe off-road use" and that the actual rating for on-road use is "much higher"....but they generally don't define "much higher".
If you swap the axle be aware that you should specify the width of the spring seats and the distance from hub to hub to be sure to get an appropriate axle. I recently put a new axle under my two axle 7K cargo trailer and due to the 5" overhang from the spring seats to the back of the the hub I needed an axle that was both larger diameter and thicker wall than a basic 3500 lb axle I could have bought locally with weld on spring seats. The locally available axle would have been de-rated from 3500 lb to less that 2600 lb due to the over hang but without doing my homework I would never have known that. Nor would any future owner..... So don't take any chances and be sure to spec an axle using the hub to hub distance and the spring seat distance.
An electric brake axle with the parking brake feature is only $60-70 more than when ordered without the parking brake. The handles and cables are the most expensive parts so take advantage of them and get an axle with the parking brakes.
If you are going to use an RV style 7-pole connector take advantage of the back-up light wire and add a pair of LED back up lights. They are cheap, cheap cheap safety insurance. I added a pair of high output ones to my cargo trailer for about $60 and they sure make a difference. And each draws a whopping 0.08 Amp at 12 volts so they use next to no power. LED lights are well worth the money. For my 16' cargo thrailer if all of the clearance lights, porch lights, interior lights, back up lights and tail lights were on at the same time the trailer would draw just about 2 Amps.
Lastly, be sure to add any required clearance lights and reflectors. There are several websites that show what is needed.
I get most all of my trailer parts, except axles, from Eastern Marine including air brake parts. They have always given me good advice and great service.
I have a nice M105A3 with all fiberglass racks and a good top that I was thinking of selling but now you folks have me thinking of keeping it.....
Lance
Luked
Oregon
Hi,
I used the above 7-blade guide to try to rewire my trailer (m103-a2) and the taillights aren’t working, brakes and turns are, I switched to 97 bulbs. I have a black, a red, and a red with green stripe wire that are unattached. Does anybody have any advice? I’m not terribly technical and am nervous about messing things up further if I start troubleshooting in the dark.
Thanks!
Zed254
467
S. Hampton Roads, VA
TM 9-2330-213-14&P, page 89/449 (https://www.liberatedmanuals.com/TM-9-2330-213-14-and-P.pdf) shows wiring diagrams for
TRAILER, CHASSIS: 1-1/2-TON, 2-WHEEL
M103A1 (NSN 2330-00-835-8629)
M103A3 (NSN 2330-00-141-8052)
I could not find any information on the A2 version.
Wires should have an aluminum ID tag on them. Use that number to match up with the wiring diagram. And check your ground wires - my M1101/LTT trailers have a ground wire attached to trailer at each light fixture.
