M105A2 and M101A1 trailers
ralbelt
9
West Warwick, R.I.
I have towed my M101 with my M1008 with stock tires and it sits perfectly level. I would think that an M105 would be nose down since its designed for a deuce.
maplehillfrm
binghamton ny
the 105 will not sit level, unless you flip the lunnette,, and add a large extension to your pintle hitch to raise it up,, otherwise it will nose down for sure,,,it can be hauled with a pickup style truck but remember it weighs in at 2750 lbs empty,, does not leave alot for freight,,
the 101 /116 are a perfect match for your pickup style truck as they were made for the size, they sit level, are easy to turn, and weigh less than 1000 lbs so you can put something on them, hope that helps,pat
NMC_EXP
12
Raton, New Mexico
The M105 is too heavy and probably too tall at the hitch.
On a hard level surface you can roll the M101 around by hand a ways. They pull easy too. Having the racks an canvas up does stop a lot more wind at hiway speed.
Regards
Jim
